RG-S5310-24GT4XS-E |
RG-S5310-24GT4XS-P-E |
RG-S5310-48GT4XS -E |
RG-S5310-48GT4XS-P-E |
RG-S5310-24SFP4XS-E |
RG-S5310-48SFP4XS-E |
Fixed port |
Power module |
Management port |
Switching Capacity |
128 Gbps |
128 Gbps |
176 Gbps |
176 Gbps |
128 Gbps |
176 Gbps |
Packet Forwarding Rate |
96 Mpps |
96 Mpps |
131 Mpps |
131 Mpps |
96 Mpps |
131 Mpps |
Number of MAC addresses |
32,000 |
4k/16k (authorized) |
ND table size |
2k/8k (authorized) |
8k/12k (authorized) |
2,500 |
4,000 |
1,200 |
Number of IGMP groups |
2,500 |
Number of MLD groups |
1,000 |
Number of VSU members |
8 |
8 |
8 |
8 |
8 |
8 |
4.2 kg (9.26 lbs) |
4.3 kg (9.48 lbs) |
4.3 kg (9.48 lbs) |
4.6 kg (10.14 lbs) |
4.2 kg (9.26 lbs) |
4.5 kg (9.92 lbs. ) |
1.2 GHz dual-core processor |
BOOTROM |
16 MB |
Flash |
2 GB |
SDRAM |
1 GB |
Power and Consumption |
≤ 40 W |
≤ 55 W |
≤ 85 W |
≤ 108 W |
Maximum output power |
Rated input voltage |
Primary airflow |
Left/Front-to-rear airflow |
0°C to 45°C (32°F to 113°F) |
Operating altitude |
Operating noise |
< 56.5 dB |
< 57.4 dB |
< 52.4 dB |
< 58.3 dB |
< 53.7 dB |
< 53.7 dB |
Interface surge protection |
RG-S5310-E Series |
Feature |
Ethernet Switching |
Super VLAN and private VLAN |
IP Service |
GRE tunnel |
IP Routing |
OSPFv2, OSPFv3, and GR |
IS-ISv4 and IS-ISv6 |
BGP4 and BGP4+ |
IPv4/IPv6 VRF |
IPv4/IPv6 PBR |
IGMPv1/v2/v3 |
IGMPv1/v2 snooping |
IGMP fast leave |
MLDv1/v2 and MLD proxy |
MLDv1/v2 snooping |
PIM-SMv6 |
Multicast querier |
Global ACLs |
Port traffic identification |
Port traffic rate limiting |
Rate limiting in each queue |
Multiple AAA modes |
RADIUS and TACACS+ |
SSHv1 and SSHv2 |
Global IP-MAC binding |
ICMPv6 |
Port security |
SAVI |
ARP spoofing prevention |
REUP |
RLDP |
DLDP |
Basic LACP Inter-VSU AP |
RSPAN and ERSPAN |
sFlow |
SNTP |
CLI (Telnet/Console) |
FTP and TFTP |
SNMP v1/v2/c3 |
Web |
Syslog/Debug |
NETCONF |
MACC |
CWMP |
VXLAN |
VXLAN (authorized) |
RG-S5310-48GT4XS-E |
RG-PA70IB |
70 W AC power module |
RG-PA150IB-F |
150 W AC power module |
RG-PA600I-P-F |
RG-PA1000I-P-F |
RG-VXLAN-MPLS-ENTRY-LIC |
Mini-GBIC-SX-MM850 |
Mini-GBIC-LX-SM1310 |
Mini-GBIC-LH40-SM1310 |
Mini-GBIC-ZX100-SM1550 |
Contactați-ne
