Deployed in data centers, MANs, or campus networks (with or without data centers) scenarios according to business needs.
RG-N18007 |
RG-N18012 |
Fan module |
M07-FAN |
2 x M12-FAN-R fan modules |
Power module |
System power: 4 PoE power: 2 |
System power: 6 PoE power: 2 (the power module must adapt to the PoE power frame) |
Expansion slot |
Supervisor module slots: 2 Line card slots: 5 |
CM slots: 2 Line card slots: 10 Switch fabric module slots: 4 |
Supervisor module slot |
2 |
2 |
Line card slot |
5 |
10 |
Switch fabric module slot |
4 |
Packet forwarding rate |
8,900 Mpps |
17,800 Mpps |
System switching capacity |
12 Tbps |
24 Tbps |
MAC address |
Number of global MAC addresses: ● ED card: 128K (default) and 512K (max.) ● DC card: 96K (default) and 288K (max.) ● EH card: 136K (default) and 136K (max.) Number of static MAC addresses: 10,000 |
● ED card: 170,000 ● DC card: 75,000 ● EH card: 170,000 |
● ED card: 170,000 (default) ● DC card: 75,000 (default) ● EH card: 170,000 (default) |
ND table size |
ED card: 75,000 (default) DC/EH card: 45,000 (default) |
12,000 (default) |
12,000 (default) |
● ED card: 16,000 (default) ● DC card: 16,000 (default) ● EH card: 4,000 (default) and 8,000 (max.) |
IPv6 hardware routing table size: 6,000 (default) Size of the routing table with a subnet mask of 65 to 128 bits: 1,000 (default) |
● ED card: 8,000 (default) ● DC card: 8,000 (default) ● EH card: 2,000 (default) and 4,000 (max.) |
Number of IGMP groups |
1,024 |
Number of MLD groups |
1,024 |
ACL entries |
● Maximum number of ingress ACEs associated with an SVI, physical interface, or aggregate interface ED card: 7,000 DC card: 8,000 EH card: 1,000 ● Maximum number of egress ACEs associated with an SVI, physical interface, or aggregate interface: 1,000 |
Number of VSU members |
2 |
2 |
Stacking bandwidth |
≥ 2.56 Tbps |
442 mm x 598 mm x 352.8 mm (17.40 in. x 23.54 in. x 13.89 in.), 8 RU |
442 mm x 725 mm x 708.4 mm (17.40 in. x 28.54 in. x 27.89 in.), 16 RU |
30.2 kg (66.58 lbs) |
105 kg (231.49 lbs) |
Supervisor module: ● M18007-CM II: 1.0 GHz 32-core processor Line card: ● ED card: 1.0 GHz quad-core processor |
Supervisor module: ● M18012-CM II: 1.0 GHz 32-core processor Line card: ● ED/DC: 1.0 GHz quad-core processor Switch fabric module: ● M18012-FE-D I: 1.0 GHz quad-core processor |
Flash memory and SDRAM |
Flash memory: ● M18007-CM II/ED/DC card: 512 MB SDRAM: ● M18007-CM II: DDRIII 16 GB ● ED/DC card: 1 GB ● 16XS2QXS: 4 GB |
Flash memory: ● ED/DC/EH card: 512 MB SDRAM: ● M18012-CM II: 16 GB ● M18012-FE-D I: DDRIII 1 GB ● ED/DC: 1 GB ● EF card: 2 GB ● 12CQ-EH/16XS2QXS: 4 GB |
Data packet buffer |
ED card: 5 MB DC card: 16 MB |
ED card: 5 MB DC card: 16 MB 12CQ-EH: 16 MB |
Power and Consumption |
RG-PA1600I: 90 V to 180 V Power: 1,200 W; 180 V to 264 V Power: 1,600 W RG-PA600I: 90 V to 180 V Power: 600 W; 180 V to 264 V Power: 600 W RG-PD600I: –40 V to –75 V Power: 600 W 210 V to 264 V Power: 3,000 W |
Rated input voltage |
RG-PA1600I: 100 V to 120 V, 200 V to 240 V, 50/60 Hz RG-PA600I: 100 V to 120 V, 200 V to 240 V, 50/60 Hz RG-PD600I: –48 V DC |
RG-PA1600I: 90 V to 264 V, 47 Hz to 63 Hz RG-PA600I: 90 V to 264 V, 47 Hz to 63 Hz RG-PD600I: –40 V DC to –75 V DC |
> 200,000 hours |
Primary airflow |
Right-to-left airflow Supervisor module and line card: right-to-left airflow Power module: built-in fans for drawing air outward Front-to-rear airflow |
Front-to-rear airflow Supervisor module and line card: air inlet at the front bottom and air outlet at the top back (M12-FAN-R) |
0°C to 50°C (32°F to 122°F) with the height in the range of –500 m to +5,000 m (–1640.42 ft. to + 16404.20 ft.) |
Operating noise |
59.3 dB at the temperature of 35°C (95°F) 68.4 dB at the temperature of 50°C (122°F) |
63.5 dB at the temperature of 35°C (95°F) 77.4 dB at the temperature of 50°C (122°F) |
Port surge protection |
All electrical ports: common mode 4 kV, differential mode 1 kV |
6 kV |
RG-N18000 Series |
Feature |
Edge Virtual Bridging (EVB) |
Virtual Ethernet Port Aggregator (VEPA) Automatic migration of VM policies |
Behavior control |
URL audit User locating |
Central authentication |
Concurrence of 90,000 IPv4 and IPv6 double stack users with an authentication capacity of 1,200 terminals per second 802.1X/Portal/MAC/IPoE authentication modes Portal authentication, RADIUS, and TACACS+ login authentication Layer 2 Portal and Layer 3 Portal access authentication Flow-based charging, flow control, and refined management Gateway authentication |
Ethernet switching |
IEEE 802.1Q |
IEEE 802.3az EEE |
Super-VLAN and private VLAN |
Port-based, protocol-based, and IP subnet-based VLAN assignment |
Basic QinQ, selective QinQ, and QinQ termination |
IP service |
Static and dynamic ARP |
DHCP client |
DHCP relay |
DHCP server |
DHCP snooping |
DHCPv6 relay |
IP routing |
OSPFv2 and OSPFv3 |
GR |
IPv4/IPv6 IS-IS |
BGP4 and BGP4+ |
IPv4/IPv6 VRF |
Policy-based routing (PBR) |
GRE tunnel |
IPv6: manual tunnel, automatic tunnel, and ISATAP tunnel |
IGMP v1/v2/v3 and IGMP proxy |
IGMP snooping v1/v2/v3 |
IGMP fast leave |
PIM-DM, PIM-SM, and PIM-SSM |
PIM-SSM for IPv4 |
MLD and MLD proxy |
PIM-SMv6 |
Multicast forwarding in a VLAN and multicast replication between VLANs |
Multicast load balancing |
Standard ACL |
Extended ACL |
MAC extended ACL |
Expert ACL |
ACL80 and IPv6 ACL |
Applying ACLs globally |
Port traffic identification |
Port-based rate limit |
IEEE 802.1p |
Eight queues on each port |
Rate limiting in each queue |
MAC address bypass (MAB) authentication, and interface-based and MAC address-based 802.1X authentication |
SSHv1.5 and SSHv2.0 |
Global IP-MAC binding |
ICMP (discarding ICMP packets of which the rate exceeds the threshold on an interface) |
Port security |
uRPF |
DAI |
Login authentication and password security |
Unknown multicast packets are not sent to the CPU, and unknown unicast packets can be suppressed. |
ITU-T Y.1731 |
Rapid Link Detection Protocol (RLDP), Layer 2 link connectivity detection, and unidirectional link detection |
IPv4 VRRPv2/v3 and IPv6 VRRPv3 |
BFD for VRRP/OSPF/BGP4/ISIS/ISISv6/ MPLS/static routing |
GR for OSPF/IS-IS/GBP |
Independent switch fabric modules and supervisor modules to separate the forwarding plane from the control plane |
1+1 redundancy for supervisor modules |
N+1 redundancy for switch fabric modules |
N+M redundancy for power modules and fan modules |
Passive backplane design, eliminating single point of failures |
Hot swapping of components |
Hot patching function for online patch upgrade |
IP FRR |
ISSU |
Independent PoE power supply slots, ensuring power supply stability of other service modules |
Hot swapping of power modules and fan modules |
Virtual Switching Unit (VSU) *Virtual Switch Device (VSD) |
SPAN and RSPAN |
sFlow |
NTP |
FTP, TFTP, and Xmodem |
SNMP v1/v2c/v3 |
Multiple types of RMON groups, including event groups, alarm groups, history groups, and statistics groups RMON Ethernet statistics, historical statistics, and alarms |
CWMP |
OpenFlow Special 1.3 |
Flow table analysis for all protocols Transmission of specified packets to the controller Configuring the controller IP address and port Notification of port status changes to the controller |
Console/AUX Modem/Telnet/SSH2.0 CLI configuration |
Fault alarm and automatic restoration |
System operation logging |
Data Center Manageability Interface (DCMI) used to remotely power on, power off, reset, and monitor the device |
Many-to-one mirroring, one-to-many mirroring, and flow-based mirroring VLAN mirroring |
RG-N18007 |
7-slot chassis (no power module), equipped with fan modules |
RG-N18012 |
12-slot chassis (no power module), equipped with fan modules |
M18007-CM II |
RG-N18007 2nd-generation supervisor module |
M18012-CM II |
RG-N18012 2nd-generation supervisor module |
RG-PA600I |
Generic power module of RG-N18000 series (redundancy, AC, 600 W, 10 A) |
RG-PD600I |
Generic power module of RG-N18000 series (redundancy, DC, 600 W, 20 A) |
RG-PA1600I |
Generic power module of RG-N18000 series (redundancy, AC, 1600 W, 16 A) |
M18012-FE-D I |
RG-N18012 switch fabric module |
M18000-44SFP4XS-ED |
44 x GE optical ports (SFP and LC) + 4 x 10GE optical ports (SFP+ and LC) |
M18000-48GT-ED |
48 x GE electrical ports (RJ45) |
M18000-24GT20SFP4XS-ED |
24 x GE electrical ports (RJ45) + 20 x GE optical ports (SFP and LC) + 4 x 10GE optical ports (SFP+ and LC) |
M18000-16XS2QXS-ED |
16 x 10GE optical ports (SFP+ and LC) + 2 x 40GE optical ports (QSFP+ and MPO) |
M18000-48XS-DC |
48 x 10GE optical ports (SFP+ and LC) |
M18000-24XS4QXS-DC |
24 x 10GE optical ports (SFP+ and LC) + 4 x 40GE optical ports (QSFP+ and MPO) |
M18000-12QXS-DC |
12 x 40GE optical ports (QSFP+ and MPO) |
M18000-12CQ-EH |
12 x 100GE optical ports (QSFP28) |
Contactați-ne
