RG-CS83-24GT4XS-PD |
RG-CS83-48GT4XS-PD |
Fixed ports |
24 x 10/100/1000 BASE-T ports 4 x 1G/10G SFP+ ports PoE standards: IEEE 802.3af and 802.3at |
48 x 10/100/1000 BASE-T ports 4 x 1G/10G SFP+ ports PoE standards: IEEE 802.3af and 802.3at |
Fans modules |
1 x fixed fan module |
Power modules |
Fixed management ports |
1 x MGMT port, 1 x console port, and 1 x USB port |
Packet forwarding rate |
96 Mpps |
132 Mpps |
Switching capacity |
128 Gbps |
176 Gbps |
MAC address table size |
32,000 |
4,000 |
8,000 |
2,500 |
4,000 |
1,200 |
Ingress: 3,500 Egress:1,500 |
Number of VSU members |
4 |
VLAN translation |
4,094 |
442 x 420 x 43.6 mm (17.40 x 16.54 x 1.72 in), 1 RU |
4.3 kg (9.48 lbs) |
4.6 kg (10.14 lbs) |
Dual cores, with the clock speed of 1.2 GHz |
Flash memory |
2 GB |
BootROM |
16 MB |
SDRAM |
1 GB |
Data packet buffer |
3 MB |
Power and Consumption |
< 65 W (non-PoE) < 810 W (PoE full load) |
< 75 W (non-PoE) < 1570 W (PoE full load) |
Maximum output power |
RG-PA600I-P-F: 600 W (PoE: 370 W) RG-PA1000I-P-F: 176 V AC to 290 V AC, 1000W 90 V AC to 176 V AC, 930 W (PoE: 740 W) |
Rated input voltage |
RG-PA600I-P-F: AC: 100 V AC to 240 V AC, 50/60 Hz HVDC: 240 V DC RG-PA1000I-P-F: AC: 100 V AC to 240 V AC, 50/60 Hz HVDC: 240 V DC |
RG-PA600I-P-F: AC: 90 V AC to 264 V AC, 47/63 Hz HVDC: 192 V DC to 288 V DC RG-PA1000I-P-F: AC: 90 V AC to 264 V AC, 47/63 Hz HVDC: 192 V DC to 288 V DC |
≥ 356,000 hours (dual power modules) ≥ 208,000 hours (single power module) |
≥ 315,000 hours (dual power modules) ≥ 193,000 hours (single power module) |
Primary Airflow |
0°C to 45°C (32°F to 113°F) |
Operating noise |
27°C: 51.6 dB 45°C: 57.4 dB |
27°C: 51.6 dB 45°C: 58.3 dB |
Interface surge protection |
RG-CS83-PD Series |
Feature |
Ethernet switching |
IEEE 802.1Q (4K VLANs) |
Super VLAN and private VLAN |
MAC VLAN, port-based VLAN, protocol-based VLAN, and IP-subnet based VLAN |
Basic QinQ Selective QinQ |
STP, RSTP, and MSTP |
LACP (IEEE 802.3ad) |
IP service |
ARP |
DHCP snooping |
DHCPv6 snooping |
IP routing |
RIP, RIPng |
BGP4 and BGP4+ |
IPv4 and IPv6 VRF |
IPv4 and IPv6 PBR |
IGMP v1/v2/v3 snooping |
PIM-DM, PIM-SM, and PIM-SSM |
MSDP |
MLD v1/v2 |
MLD snooping v1/v2 |
PIM-SMv6, PIM-SSM v6 |
Standard IP ACLs Extended IP ACLs Extended MAC ACLs ACL80 IPv6 ACL |
Port traffic identification |
Port traffic rate limiting |
Traffic policing: CAR |
Rate limiting in each queue |
Multiple AAA modes |
RADIUS and TACAS+ |
Allowlist |
HTTPS |
SSHv1, SSHv2 |
Global IP-MAC binding |
ICMP |
IP Source Guard |
SAVI |
Gateway ARP anti-spoofing |
CPP(CPU Protection Policy) |
NFPP( Network Foundation Protection Policy) |
REUP, RLDP, DLDP |
BFD |
SPAN, RSPAN, and ERSPAN |
sFlow |
NTP and SNTP |
FTP and TFTP |
SNMP v1/v2/v3 |
RMON (1, 2, 3, 9) |
NETCONF |
Cloud and SON |
24 x 10/100/1000M adaptive electrical ports, 4 x 1G/10G SFP+ ports, supporting PoE remote power supply and the maximum PoE output power of 740 W. (Purchase at least one RG-PA600I-P-F/RG-PA1000I-P-F module.) |
48 x 10/100/1000M adaptive electrical ports, 4 x 1G/10G SFP+ ports, supporting PoE remote power supply and the maximum PoE output power of 1480 W. (Purchase at least one RG-PA600I-P-F/RG-PA1000I-P-F module.) |
RG-PA600I-P-F |
RG-PA1000I-P-F |
1000 W AC power module, PoE power module |
Mini-GBIC-SX-MM850 |
Mini-GBIC-LX-SM1310 |
Mini-GBIC-LH40-SM1310 |
Single-port 1000BASE-LH mini GBIC module (LC interface), supporting a transmission distance of 40 km |
Mini-GBIC-ZX100-SM1550 |
Contactați-ne
