RG-S5300-24GT4XS-E |
RG-S5300-24GT4XS-P-E |
RG-S5300-48GT4XS-E |
Fixed port |
24 x 10/100/1000M auto-negotiation electrical ports, 4 x 1G/10G SFP+ ports |
48 x 10/100/1000M auto-negotiation electrical ports, 4 x 1G/10G SFP+ ports |
Power module |
Built-in power module |
Fixed management port |
1 x MGMT port, 1 x console port, and 1 x USB port |
Packet forwarding rate |
96 Mpps |
96 Mpps |
132 Mpps |
System switching capacity |
128 Gbps |
128 Gbps |
176 Gbps |
Number of MAC addresses |
32,000 |
2,000 |
ND table size |
1,000 |
4,000 |
2,500 |
2,000 |
1,200 |
Number of VSU members |
4 |
Number of IGMP groups |
2,500 |
Number of MLD groups |
1,000 |
Number of VRFs |
512 |
442 mm x 220 mm x 43.6 mm (17.40 in. x 8.66 in. x 1.72 in.), 1 RU |
Weight (full load) |
2.7 kg (5.95 lbs) |
3 kg (6.61 lbs) |
3 kg (6.61 lbs) |
1.2 GHz dual-core processor |
Storage |
Flash memory: 2 GB SDRAM: 1 GB |
Power and Consumption |
< 40 W |
System power consumption (without PoE load) < 65 W System power consumption (with PoE load) < 410 W |
< 55 W |
Rated input voltage |
AC input: 100 V to 240 V Frequency: 50/60 Hz |
AC input: 90 V to 264 V |
> 200,000 hours |
Primary airflow |
Front-to-rear airflow |
0°C to 45°C (32°F to 113°F) at an altitude in the range of 0 m to 1,800 m (5905.51 ft.) Altitude 1,800 m (5905.51 ft.) to 5,000 m (16404.20 ft.): The maximum temperature decreases by 1°C (1.8°F) each time the altitude increases by 220 m (721.78 ft.). |
Operating altitude |
0 m to 5,000 m (16404.20 ft.) |
Operating noise |
40.9 dB at the temperature of 27°C (80.6°F) 48.8 dB at the temperature of 45°C (113°F) |
33.5 dB at the temperature of 27°C (80.6°F) 53.9 dB at the temperature of 45°C (113°F) |
40.3 dB at the temperature of 27°C (80.6°F) 53.1dB at the temperature of 45°C (113°F) |
Interface surge protection |
Communication port: 10 kV (common mode) (MGMT port: 4 kV) Power port: 6 kV (common/differential mode) |
RG-S5300-E Series |
Feature |
Ethernet switching |
Super VLAN and private VLAN |
ERPS (G.8032 v1/v2), sing ring, tangent ring, intersecting ring, and load balancing |
IP service |
IPv6 addressing, IPv6 ping, and IPv6 tracert |
GRE tunnel |
IP routing |
OSPFv2 and OSPFv3 |
IS-ISv4 and IS-ISv6 |
BGP4 and BGP4+ |
Routing policy |
IPv4/VRF |
IPv4/IPv6 PBR |
IGMPv1/v2/v3 |
IGMPv1/v2 snooping |
IGMP fast leave |
MLDv1/v2 and MLD proxy |
MLDv1/v2 snooping |
PIM-SMv6 |
Time based ACLs, ACL 80, and IPv6 ACL |
Global ACLs |
Port traffic identification |
Port traffic rate limiting |
Multiple AAA modes |
RADIUS |
RADIUS and TACACS+ |
SSHv1 and SSHv2 |
Global IP-MAC binding |
ICMP |
Port security |
SAVI |
ARP spoofing prevention |
3-tuple binding (IP address, MAC address, and port) 3-tuple binding (IPv6 address, MAC address, and port) Filtering of invalid MAC addresses Port- and MAC address-based 802.1X authentication MAB authentication Portal authentication and Portal 2.0 authentication ARP check DAI ARP packet rate limiting Gateway ARP spoofing prevention Broadcast storm suppression Hierarchical management of administrators and password protection BPDU guard Port protection |
REUP |
SPAN, RSPAN, and ERSPAN |
sFlow |
SNTP |
CLI (Telnet/Console) |
FTP and TFTP |
SNMP v1/v2c/c3 |
Web |
Syslog/Debugging |
NETCONF |
MACC |
CWMP |
RG-S5300-24GT4XS-P-E: IEEE 802.3af and 802.3at power supply standards Automatic and energy-saving power supply management modes Uninterrupted power supply in hot start mode Scheduled power-on or power-off of PoE ports based on the time policy Port priority |
24 x 10/100/1000M auto-negotiation electrical ports, 4 x 1G/10G SFP+ ports, supporting PoE and a maximum PoE output power of 370 W |
1000BASE-TX, SFP Transceiver (100 m) |
Mini-GBIC-SX-MM850 |
1000BASE-SX, SFP Transceiver, SM (850 nm, 500 m, LC) |
Mini-GBIC-LX-SM1310 |
1000BASE-LX, SFP Transceiver, SM (1310 nm, 10 km, LC) |
Mini-GBIC-LH40-SM1310 |
1000BASE-LH, SFP Transceiver, SM (1310 nm, 40 km, LC) |
Mini-GBIC-ZX100-SM1550 |
1000BASE-ZX100, SFP Transceiver, SM (1550 nm, 100 km, LC) |
10GBASE-SR, SFP+ Transceiver, MM (850 nm, 300 m, LC) |
10GBASE-SR, SFP+ Transceiver (1310nm, 10 km, LC) |
10GBASE-SR, SFP+ Transceiver (1550nm, 40 km, LC) |
Contactați-ne
