Hareware Specifications |
RG-S6150-24VS8CQ-X |
RG-S6150-48VS8CQ-X |
Fixed port |
24 x 10GE/25GE (license required for 25G*) SFP28 ports 8 x 40GE/100GE QSFP28 ports |
48 x 10GE/25GE (license required for 25G*) SFP28 ports 8 x 40GE/100GE QSFP28 ports |
Fan module |
4 x fan modules 3+1 redundancy, at least three fan modules required for the system Fan speed regulating and fault alarming |
Power module |
2 x hot-swappable power modules |
Fixed management port |
System switching capacity |
2.8 Tbps |
4 Tbps |
Number of MAC addresses |
Number of global MAC addresses: 128,000 (default) Number of static MAC addresses: 10,000 |
96,000 (default) |
96,000 (default) |
ND table size |
80,000 (default) |
80,000 (default) |
350,000 (default) |
350,000 (default) |
4,000 |
4,000 |
65,000 (default) |
65,000 (default) |
2,000 |
2,000 |
Ingress: 28,000 Egress:4,000 |
Number of IGMP groups |
4,000 |
Number of MLD groups |
1,000 |
Number of VSU members |
4 |
4 |
Number of VRFs |
1,024 |
1,024 |
442 mm x 387 mm x 44 mm (17.40 in. x 15.24 in. x 1.73 in.) |
Weight (four fan modules and two power modules at full load) |
10 kg (22.05 lbs) |
10 kg (22.05 lbs) |
2.2 GHz quad-core processor |
Storage |
DDR4 4 GB 8 GB flash memory |
Data packet buffer |
35 MB |
35 MB |
Power and Consumption |
270 W |
300 W |
Maximum output power |
PA550I II-F: 90–264 V AC or 100–240 VAC, 550 W |
Rated input voltage |
AC input: 100 V AC to 240 V AC Frequency: 50/60 Hz HVDC input: 240 V DC |
AC input: 90 V AC to 264 V AC HVDC input: 192 V DC to 288 V DC |
> 200,000 hours |
> 200,000 hours |
Primary airflow |
Front-to-rear airflow |
0°C to 45°C (32°F to 113°F) |
Maximum operating altitude |
5000 m (16404.20 ft.) |
Interface surge protection |
Telecom port: 4 kV (MGMT port) |
RG-S6150-X Series |
Feature |
Ethernet switching |
Super-VLAN and private VLAN |
LACP (IEEE 802.3ad) |
IP service |
Static and dynamic ARP |
GRE tunnel |
IP routing |
SVI: 4k supported |
OSPFv2 and OSPFv3 |
GR |
IS-ISv4 and IS-ISv6 |
BGP4 and BGP4+ |
MCE |
Stateless auto configuration |
IPv4/IPv6 VRF |
IPv4/IPv6 PBR |
IGMPv1/v2/v3 and IGMP proxy |
IGMPv1/v2/v3 snooping |
PIM-DM, PIM-SM, and PIM-SSM |
PIM-SSM for IPv4 and IPv6 |
MLDv1/v2 |
MLD snooping |
MSDP |
PIM-SMv6 |
Multicast querier |
MPLS |
MPLS L3VPN |
6PE/6VPE interconnection with IPv4/IPv6 MPLS backbone network |
MPLS MIB (RFC1273, 4265, 4382) |
Time-based ACLs |
ACL80 and IPv6 ACL |
Port traffic identification |
Port traffic rate limiting |
Eight queues on each port |
Rate limiting in each queue |
Multi-AAA |
RADIUS and TACAS+ |
Filtering of invalid MAC addresses Broadcast storm suppression BPDU guard |
SSHv1 and SSHv2 |
Global IP-MAC binding |
ICMPv6 |
SAVI |
ARP spoofing prevention |
3-tuple binding (IP address, MAC address, and port) ARP spoofing prevention 3-tuple binding (IPv6 address, MAC address, and port) Filtering of invalid MAC addresses MAB authentication Portal authentication and Portal 2.0 authentication ARP check DAI ARP packet rate limiting Gateway ARP spoofing prevention Broadcast storm suppression SSH BPDU guard |
REUP |
RLDP |
BFD |
Hot swapping of fan modules |
VSU |
SPAN, RSPAN, and ERSPAN |
sFlow |
NTP an SNTP |
FTP and TFTP |
SNMP v1/v2/c3 |
RMON (1, 2, 4, 9) |
NETCONF |
CWMP |
VXLAN |
EVPN VXLAN tunnel establishment LAN access to VXLAN IPv4 over IPv4 Distributed gateway IPv6 over IPv4 Using an SVI to connect to the VXLAN network Using a routed interface to connect to the VXLAN network Proxy ARP (replying with the actual MAC address)) ND proxy (replying with the actual MAC address) ND reply (replying with the actual MAC address) EVPN VXLAN VXLAN static route Anycast gateway VXLAN bridging mode VXLAN routing mode Proxy ARP (replying with the gateway MAC address) Configuring the UDP port number in VXLAN packets Static VXLAN tunnel creation |
RG-PA550I II-F |
VG-SFP-SR-MM850 |
VG-SFP-SR-MM1310 |
VG-SFP-AOC5M |
40G-QSFP-SR-MM850 |
40G-QSFP-LR4 SM1310 |
40G-AOC-5M |
40G-AOC-10M |
100G-QSFP-SR-MM850 |
100G-QSFP-LR4-SM1310 |
100G-AOC-1M |
100G-AOC-5M |
100G-AOC-10M |
Contactați-ne
