M7800C-8SFG-XB
M7800C-8SFX-XB
RG-S7805C |
RG-S7808C |
RG-S7810C-X |
Power module |
2 |
4 |
4 |
Supervisor module slot |
2 |
2 |
2 |
Line card slot |
3 |
6 |
8 |
Switch fabric module slot |
4 |
Switching Capacity |
6 Tbps |
12 Tbps |
19.2 Tbps |
Packet Forwarding Rate |
4500 Mpps |
9000 Mpps |
14300 Mpps |
MAC address |
● M7800C-8SFX-XB: 256000 ● M7800C-8SFG-XB: 256000 ● XA card: 96000 ● XB card: 256000 |
ARP table |
● M7800C-8SFX-XB: 9600 ● M7800C-8SFG-XB: 9600 ● XA card: 4000 ● XB card: 9600 |
● M7800C-8SFX-XB: 350000 (shared with IPv4 routes) ● M7800C-8SFG-XB:350000 (shared with IPv4 routes) ● XA card:64000 (shared with IPv4 routes) ● XB card: 350000 (shared with IPv4 routes) |
4000 |
● M7800C-8SFX-XB: 65000 (shared with IPv4 routes) ● M7800C-8SFG-XB:15000 (shared with IPv4 routes) ● XA card: 65000 (shared with IPv4 routes) ● XB card: 65000 (shared with IPv4 routes) |
2000 |
● Ingress M7800C-8SFX-XB: 2800 M7800C-8SFG-XB: 2800 XA card: 7000 XB card: 2800 ● Egress M7800C-8SFX-XB: 4000 M7800C-8SFG-XB: 4000 XA card: 1500 XB card: 4000 |
Number of VSU members |
2 |
2 |
2 |
442 mm × 451 mm × 175 mm (17.40 in. x 17.76 in. x 6.89 in.) |
442 mm × 465 mm × 441.7 mm (17.40 in. x 18.31 in. x 17.39 in.) |
442.5 mm × 560 mm × 442 mm (17.42 in. x 22.05 in. x 17.40 in.) |
32.35 kg |
35.6 kg |
43.55 kg |
Rack Size |
4 RU |
10 RU |
10 RU |
2.2 GHz quad-core processor |
Storage |
Flash Memory:8 GB SDRAM:DDR4 4 GB |
Max. Output Power |
● RG-PA300I-F: 90 V AC to 180 V AC; Power: 300 W 180 V AC to 264 V AC; Power: 300 W ● RG-PA460I-F: 90 V AC to 180 V AC; Power: 460 W 180 V AC to 264 V AC; Power: 460 W ● RG-PA1000I-F: 90 V AC to 176 V AC; Power: 800 W 176 V AC to 264 V AC; Power: 1000 W |
● RG-PA600I-F: 90 V AC to 180 V AC; Power: 600 W 180 V AC to 264 V AC; Power: 600 W ● RG-PA1600I-F: 90 V AC to 180 V AC; Power: 1200 W 180 V AC to 264 V AC; Power: 1600 W |
● RG-PA1600I: 90 V AC to 180 V AC; Power: 1200 W 180 V AC to 264 V AC; Power: 1600 W ● RG-PA600I: 90 V AC to 180 V AC; Power: 600 W 180 V AC to 264 V AC; Power: 600 W ● RG-PD600I: –40 V DC to –75 V DC; Power: 600 W ● RG-PA1600I-PL: 90 V AC to 176 V AC; Power: 1200 W 176 V AC to 264 V AC; Power: 1600 W |
Maximum output power |
● M7805C-CM-X:< 40 W ● M7800C-12CQ-XB:< 240 W ● M7800C-24GT8SFP8XS-XA:< 95 W ● M7800C-32XS-XA:< 149 W ● M7800C-48XT-P-XB:< 300 W ● M7800C-48GT4XS-XA:< 85 W ● M7800C-48SFP4XS-XA:< 117 W ● M7800C-52XS-XB:< 250 W ● M7800C-8SFG-XB:< 250 W ● M7800C-8SFX-XB:< 250 W |
● M7808C-CM-X:< 62 W ● M7800C-12CQ-XB:< 240 W ● M7800C-24GT8SFP8XS-XA:< 95 W ● M7800C-32XS-XA:< 149 W ● M7800C-48XT-P-XB:< 300 W ● M7800C-48GT4XS-XA:< 85 W ● M7800C-48SFP4XS-XA:< 117 W ● M7800C-52XS-XB:< 250 W ● M7800C-8SFG-XB:< 250 W ● M7800C-8SFX-XB:< 250 W |
● M7810C-CM-X:< 60 W ● M7800C-12CQ-XB:< 240 W ● M7800C-24GT8SFP8XS-XA:< 95 W ● M7800C-32XS-XA:< 149 W ● M7800C-48XT-P-XB:< 300 W ● M7800C-48GT4XS-XA:< 85 W ● M7800C-48SFP4XS-XA:< 117 W ● M7800C-52XS-XB:< 250 W ● M7800C-8SFG-XB:< 250 W ● M7800C-8SFX-XB:< 250 W ● M7810C-FE-X I:< 50 W ● M7810C-FE-X II:< 160 W |
> 200,000 hours |
Primary Airflow |
● Supervisor module: air intake from the right and exhaust from back ● Service module: air intake from the right and exhaust from back ● System power module: drawing air outward with built-in fans, air intake from the front panel and exhaust from back |
● Supervisor module /Service module: air intake from the right and exhaust from back, drawing air outward to form convection for heat dissipation ● System power module: air intake from the front panel and exhaust from back, drawing air inward to form convection for heat dissipation |
● Line card: air intake from the side and exhaust from back ● Supervisor module/Switch fabric module: air intake from the front panel and exhaust from back |
Operating Temperature |
0°C to 50°C (32°F to 122°F) |
Storage Temperature |
Operating Humidity |
Storage Humidity |
5% to 95% RH |
Operating Altitude |
–500 m to +5000 m (–1,640.41 ft. to +16,404.20 ft.) |
Surge Protection of Communication Ports |
6 kV |
Software Specifications |
RG-S7805C |
RG-S7808C |
RG-S7810C-X |
Ethernet switching |
802.3az EEE |
IP subnet-based VLAN |
MAC VLAN |
Port-based VLAN |
Private VLAN |
protocol-based VLAN |
Super-VLAN |
STP (IEEE 802.1.d) |
RSTP (IEEE 802.1w) |
MSTP (IEEE 802.1s) |
Device Virtualization |
VSU |
SDN |
OpenFlow 1.3 NETCONF |
IP service |
Static and dynamic ARP |
DHCP client |
DHCP relay |
DHCP server |
DHCP snooping |
DHCPv6 client |
DHCPv6 relay |
DHCPv6 snooping |
FTP Server |
FTP Client |
NTP server |
NTP Client |
SNTP Client |
TFTP Client |
TFTP Server |
IP routing |
BGP4 |
BGP4+ |
IS-ISv4 |
IS-ISv6 |
OSPFv2 |
OSPFv3 |
RIP |
RIPng |
GR |
Routing Policy |
ECMP |
IPv4/IPv6 VRF |
Policy-based routing (PBR) |
IGMP v1/v2/v3 |
IGMP snooping v1/v2 |
IGMP proxy |
IGMP fast leave |
PIM-DM |
PIM-SM |
PIM-SSM for IPv4 and IPv6 |
MLDv1 and MLDv2 |
Multicast static routing |
MLD v1/v2 snooping |
PIM-SMv6 |
Multicast source IP address check |
Multicast source port check |
MPLS |
MPLS L3VPN |
MPLS 6VPE |
MPLS IPv6 |
MPLS forwarding |
LDP |
LSP |
VXLAN |
VXLAN Layer 2 bridge |
VXLAN Layer 3 gateway |
EVPN VXLAN |
Standard IP ACL |
extended IP ACL |
extended MAC ACL |
Layer 2 and Layer 3 port ACL |
VLAN ACL |
Expert-level ACL |
ACL 80 |
IPv6 ACL |
Applying ACLs globally |
ACL COUNTER |
ACL LOGGING |
ACL REMARK |
802.1P |
SP |
WRR |
SP+WFR |
other queue scheduling mechanisms |
RED/WRED |
Rate limiting based on the inbound or outbound interface |
MPLS QOS |
1+1 redundancy for supervisor modules |
Hot swapping of all components |
N+M redundancy for power supply |
1+1 fan redundancy |
Hot patching function for online patch upgrade |
GR |
BFD |
VRRP |
VRRP+ |
Faulty optical port isolation |
Dual physical chips for boot systems |
NFPP |
CPP |
DAI |
port security |
802.1X authentication |
MAC address-based authentication |
Portal authentication |
RADIUS |
TACACS+ login authentication |
uRPF |
SSHv2 |
IPv6 SAVI |
Login authentication and password security |
providing encrypted security channels for user login |
Unknown multicast packets are not sent to the CPU, and unknown unicast packets can be suppressed. |
Console/AUX Modem/Telnet/SSH2.0 CLI configuration |
File upload and download management using FTP, TFTP, and Xmodem |
SNMP V1/V2c/V3 |
RMON |
CWMP |
GRPC |
Fault alarm and auto-recovery |
System operation logging |
sFlow |
SPAN |
RSPAN |
ERSPAN |
VLAN mirroring |
Web-based NMS |
Energy-Saving Design |
IEEE 802.3az Energy Efficient Ethernet |
RG-S7810C-X |
RG-S7810C-X switch, which can accommodate eight line cards, two supervisor modules, and four switch fabric modules |
S7808C |
RG-S7808C switch, which can accommodate six line cards and two supervisor modules. When the M7808C-CM-X supervisor module is used, you can select line cards of the RG-S7800C-X series. |
S7805C |
RG-S7805C switch, which can accommodate six line cards and two supervisor modules. When the M7805C-CM-X supervisor module is used, you can select line cards of the RG-S7800C-X series. |
M7810C-CM-X |
RG-S7810C-X high-performance supervisor module |
M7805C-CM-X |
RG-S7805C high-performance supervisor module |
M7808C-CM-X |
RG-S7808C high-performance supervisor module |
Notes:
RG-PA300I-F |
S7805C power module (AC, 300 W, 10 A) |
RG-PA460I-F |
S7805C power module (available for redundancy, AC, 460 W, 10 A) |
RG-PA600I-F |
S7808C power module (available for redundancy, AC, 600 W, 10 A) |
RG-PA1000I-F |
S7805C Power module (support redundancy, AC, 1000W,10 A) |
RG-PA1600I-F |
S7808C power module (available for redundancy, AC, 1600 W, 16 A) |
RG-PA1600I-PL |
Common PoE power module (available for redundancy, AC, 1600 W, 16 A) |
RG-PA600I |
S7810C-X power module (available for redundancy, AC, 600 W, 10 A) |
RG-PD600I |
S7810C-X power module (available for redundancy, DC, 600 W, 20 A) |
RG-PA1600I |
S7810C-X power module (available for redundancy, AC, 1600 W, 16 A) |
M78-PSE-X |
Common PoE power chassis, used together with RG-PA1600I-PL |
M7810C-FE-X I |
RG-S7810C-X 1st-generation switch fabric module |
M7810C-FE-X II |
RG-S7810C-X 2nd-generation switch fabric module |
M7800C-32XS-XA |
32 x 10GE optical ports (SFP+ and LC connector) |
M7800C-24GT8SFP8XS-XA |
24 x GE electrical ports (RJ45), 8 x GE optical ports (SFP and LC connector), and 8 x 10GE optical ports (SFP+ and LC connector) |
M7800C-48GT4XS-XA |
48 x GE electrical ports (RJ45) and 4 x 10GE optical ports (SFP+ and LC connector) |
M7800C-48SFP4XS-XA |
48 x GE optical ports (SFP and LC connector) and 4 x 10GE optical ports (SFP+ and LC connector) |
M7800C-52XS-XB |
52 x 10GE optical ports (SFP+ and LC connector) |
M7800C-12CQ-XB |
12 x 100GE/40GE optical ports (QSFP+ and MPO/LC connector) |
M7800C-48XT-P-XB |
48 x 100M/GE/2.5GE/5GE/10GE electrical ports (RJ45 and PoE/PoE+) |
M7800C-8SFG-XB |
CWDM line card for RG-S7800C-X series switches, supporting eight SFG GE ports |
M7800C-8SFX-XB |
CWDM line card for RG-S7800C-X series core switches, supporting eight SFX 10GE ports with each port backward compatible with the Gigabit rate |
Contactați-ne
