RG-CS86-20XS4VS2QXS-D |
Fixed Ports |
20 x 1GE/2.5GE/10GE SFP+ ports, 4 x 10GE/25GE SFP28 ports, 2 x 40GE QSFP+ ports. One switch provides a maximum of 32 x 10GE ports, 2 x modular power slots, and 2 x modular fan slots. |
Fan module |
Dual pluggable modular fans, with front-to-rear ventilation channels Fan speed regulating and alarm function |
Power module |
2 x replaceable hot-swappable power supply slots |
Fixed management port |
1 x MGMT port, 1 x console port, and 1 x USB port |
Packet forwarding rate |
570 Mpps |
Switching capacity |
760 Gbps |
MAC address table size |
32,768 |
16,000 |
16,000 |
4,000 |
16,000 |
2,000 |
In: 2,500 Out: 1,000 |
Number of VSU members |
2 |
440 x 330 x 43.6 mm (17.32 in. x 12.99 in. x 1.72 in.), 1 RU |
Weight of the empty chassis |
4.6 kg (10.14 lbs.) |
Dual-core CPU, 1.25 GHz |
Flash memory |
1 GB |
BootROM |
16 MB |
SDRAM |
1 GB |
Data packet buffer |
4 MB |
Power and Consumption |
Power supply |
Supported power module type: RG-PA150I-F AC input: Rated voltage range: 100–240 V AC; 50/60 Hz Maximum voltage range: 90–264 V AC; 47/63 Hz Rated input current: 3 A
HVDC input: Rated voltage: 240 V DC Maximum voltage range: 192–288 V AC Rated current per circuit: 3 A |
< 85 W |
Maximum output power |
RG-PA150I-F: 150 W |
Rated input voltage |
RG-PA150I-F: AC input: Rated voltage range: 100–240 V AC; 50/60 Hz
HVDC input: Rated voltage: 240 V DC |
RG-PA150I-F: AC input: Maximum voltage range: 90–264 V AC; 47/63 Hz
HVDC input: Maximum voltage range: 192–288 V DC |
Primary airflow |
Front-to-rear airflow |
0°C to 50°C (32°F to 122°F) |
Interface surge protection |
Temperature alarm |
Supported |
Feature |
Ethernet Switching |
Super VLAN, private VLAN |
MAC VLAN, port-based VLAN, protocol-based VLAN, IP subnet-based VLAN |
Basic QinQ |
STP, RSTP, and MSTP |
LACP (IEEE 802.3ad) |
IP Service |
ARP |
DHCP snooping |
DHCPv6 snooping |
IP Routing |
BGP4 and BGP4+ |
IPv4 and IPv6 VRF |
IPv4 and IPv6 PBR |
IGMP v1/v2/v3 snooping |
PIM-DM, PIM-SM, and PIM-SSM |
MSDP |
MLD v1/v2 |
MLD snooping v1/v2 |
PIM-SMv6 and PIM-SSM v6 |
IGMP filtering, IGMP immediate leave |
Port traffic rate limiting |
Multiple AAA modes |
RADIUS and TACAS+ |
HTTPS |
SSHv1, SSHv2 |
Global IP-MAC binding |
SAVI |
Strict and loose RPF |
REUP, RLDP, DLDP |
BFD |
VSU |
SPAN, RSPAN, and ERSPAN |
sFlow |
NTP and SNTP |
FTP and TFTP |
SNMP v1/v2/v3 |
RMON (1, 2, 3, 9) |
Telnet |
NETCONF |
Cloud and SON |
20 x 1GE/2.5GE/10GE SFP+ ports, 4 x 10GE/25GE SFP28 ports, 2 x 40GE QSFP+ ports, supports up to 32 x 10GE ports, 2 x slots for power supply module, requires at least one RG-PA150I-F power supply module, 2 x slots for fan modules, 2 x pre-installed fans (Purchase at least one RG-PA150I-F module.) |
RG-PA150I-F |
150 W AC power supply module for RG-CS86-20XS4VS2QXS-D |
1000BASE-GT mini GBIC conversion module |
GE-SFP-LX20-SM1310-BIDI |
SFP BiDi transceiver-Tx1310/Rx1550, 20 km, LC |
GE-SFP-LX20-SM1550-BIDI |
SFP BiDi transceiver-Tx1550/Rx1310, 20 km, LC |
GE-SFP-LH40-SM1310-BIDI |
SFP BiDi transceiver-Tx1310/Rx1550, 40 km, LC |
GE-SFP-LH40-SM1550-BIDI |
SFP BiDi transceiver-Tx1550/Rx1310, 40 km, LC |
2.5G-SFP-LX03-SM1310-BIDI-I |
SFP 2.5G BiDi transceiver-Tx1310/Rx1550, 3 km,LC |
2.5G-SFP-LX03-SM1550-BIDI-I |
SFP 2.5G BiDi transceiver-Tx1550/Rx1310, 3 km,LC |
10G LC fiber module, applicable to SFP+ ports, max cabling distance: 300 m |
10G LC fiber module, applicable to SFP+ ports, max cabling distance: 10 km |
10G LC fiber module, applicable to SFP+ ports, max cabling distance: 40 km |
VG-SFP-SR-MM850 |
25G fiber module |
VG-SFP-LR-SM1310 |
25G fiber module |
10G SFP+ connector fiber, 1-meter long, including one cable and two connector modules |
10G SFP+ connector fiber, 3-meter long, including one cable and two connector modules |
10G SFP+ connector fiber, 5-meter long, including one cable and two connector modules |
VG-SFP-AOC5M |
25G Base SFP+ fiber cable (including modules on both ends), 5-meter long |
40G-QSFP-SR-MM850 |
40G SR fiber module, applicable to QSFP+ ports (OM3/OM4 MPO interface, 8-core, 850 nm wavelength, max cabling distance: 100 m (OM3), 150 m (OM4) |
40G-QSFP-LR4 SM1310 |
40G LR single-mode fiber module, applicable to QSFP+ ports, max cabling distance:10 km (LC, dual-core, 1310 nm wavelength) |
40G-AOC-5M |
40G QSFP+ connector fiber, 5-meter long, including one cable and two connector modules |
40G-AOC-10M |
40G QSFP+ connector fiber, 10-meter long, including one cable and two connector modules |
Contactați-ne
