RG-SG7008L |
Fixed ports |
4 x 1GE/10GE SFP+ ports |
Management ports |
1 x console port, 1 x USB port, compliant with the USB 2.0 standard |
Module slots |
6 x interface module slots (slots 1–6) 2 x multi-service module slots (slots 7 and 8) 2 x power module slots (slots PWR1 and PWR2) 1 x hard disk slot Built-in switch fabric unit (SFU) and dual fan modules |
Multi-service card slots |
M7000L-6XS (60GE optical interface card) |
M7008L-RCM (routing card) |
Common interface card slots |
M7000L-8GT (8GE electrical interface card) |
M7000L-8GT-HP (8GE electrical interface card with 8 x GE electrical interfaces for PoE/PoE+ power supply) |
M7000L-8SFP (8GE optical interface card) |
Hard disk slot |
M7000-HDD-1T (1 TB hard disk can be expanded.) |
Switching capacity |
6.4 Tbps/64 Tbps |
Packet forwarding rate |
2880 Mpps/12600 Mpps |
Chassis without cable management arm (2 U): 442 mm x 320 mm x 88 mm (17.40 in. x 12.60 in. x 3.46 in.) Chassis with cable management arm (3 U): 442 mm x 406 mm x 131.5 mm (17.40 in. x 15.98 in. x 5.18 in.) |
Net weight: about 5.95 kg (13.12 lbs.) |
Power Supply and Fan |
Power module |
RG-PA180I-F: Input: 90 V–290 V AC Output power: 180 W (12 V/180 W) RG-PA650I-P-F: Input: 90 V–290 V AC Output power: 650 W (12 V/130 W, 54.5 V/520 W) |
Power redundancy |
Power modules of the same model support 1+1 redundancy and current sharing. Power modules of different models can be used together. |
Fixed fan modules |
3 x built-in fan modules Fan speed adjustment and fan failure alarming are supported. |
0°C to 45°C (32°F to 113°F) |
5% RH to 95% RH |
Altitude |
● Long-term operating altitude: 0 m to 1800 m (0°C to 45°C, 32°F to 113°F) Note: At an altitude from 1800 m (5906 ft) to 5000 m (16404 ft), the maximum temperature decreases by 1°C (1.8°F) each time the altitude increases by 220 m (722 ft). ● Operating altitude: up to 5000 m (16404 ft) Storage altitude: up to 5000 m (16404 ft) |
Software Specifications |
Product Feature |
RG-SG7008L |
Switching module |
VLAN |
4000 IEEE 802.1Q VLANs Port-based VLAN Private VLAN Voice VLAN GVRP |
QinQ |
Basic QinQ Flexible QinQ |
Link aggregation |
LACP (IEEE 802.3ad) |
Spanning tree protocols |
STP, RSTP, and MSTP |
VXLAN |
The hardware supports Virtual Extensible LAN (VXLAN). Through software upgrade in the future, a logical Layer 2 network can be built on the basis of the Layer 3 network. |
DHCP |
DHCP server DHCP client DHCP snooping DHCP relay IPv6 DHCP server IPv6 DHCP snooping IPv6 DHCP client IPv6 DHCP relay |
IP routing |
RIP and RIPng BGP4 and BGP4+ OSPFv2, OSPFv3, IS-ISv4, and IS-ISv6 Packet-based and flow-based load balancing
IGMPv1/IGMPv2/IGMPv3 and IGMP proxy PIM-DM, PIM-SM, and PIM-SSM MLD Snooping and MLD PIM for IPv6 |
ACL |
Flexible and diversified hardware ACLs Standard IP ACLs (IP-based hardware ACLs) Extended IP ACLs (hardware ACLs based on IP addresses or TCP/UDP port numbers) MAC-based extended ACLs Time-based ACLs Expert-level ACLs IPv6 ACL |
Basic security features |
3-tuple binding (IP address, MAC address, and port) Filtering of unauthorized MAC addresses 802.1x authentication based on the port number and MAC address Portal authentication and Portal 2.0 authentication ARP check, ARP packet rate limiting, gateway-targeted ARP spoofing prevention Port protection Broadcast storm suppression Hierarchical management and password protection of administrators RADIUS and TACAS+ AAA for device login management SSHv2 to provide a secure, encrypted connection for user login BPDU Guard CPP and NFPP Attack defense, DoS/DDoS defense, fragmentation attack defense, SYN attack defense, and IP spoofing attack defenseL2TP, IPsec VPN, GRE |
Management features |
SNMP, CLI (Telnet/Console), RMON, SSH, syslog, NTP/SNTP, SNMP over IPv6, IPv6 MIB support for SNMP, SSH over IPv6, Telnetv6, FTPv6/TFTPv6, DNSv6, NTP for IPv6, and Traceroute for IPv6 CLI configurations including the console port, auxiliary port, Telnet, or SSH File transfer protocols such as FTP, TFTP, and XMODEM sFlow, which utilizes the random sampling technology to sample flow information on the traffic of a switch WIS-based management |
High reliability |
VSU (virtualizing multiple devices into one device) |
Routing module |
IPv4 features |
LLDP, 802.1Q, 802.1p, 802.3ad, and other Ethernet features Static routing, RIPv1/RIPv2, OSPFv2, BGP, IS-IS, PBR, and routing policies VRRP, FTP, and TFTP ECMP and WCMP Static and dynamic NAT, static and dynamic NAPT, and VPN NAT DNS resolution and smart DNS NTP server and NTP client |
IPv6 features |
IPv6 addressing, Neighbor Discovery (ND), ICMPv6, Stateless Auto Configuration, and Path MTU Discovery Static routing, RIPng, OSPFv3, BGP4+, IS-ISv6, ECMP, and PBR VRRPv3, BFDv6, and 6VPE IPv6 ACL, NAT64, NAT-PT, DHCPv6, DNSv6, FTPv6, and TFTPv6 Manual tunnel, automatic tunnel, ISATAP, and GRE tunnel |
MPLS |
MPLS forwarding, MPLS VPN/VPLS MPLS VPN inter-AS option A/B/C
SSL VPN |
Enabled by default; supporting access on the web page and iOS, macOS, Windows, and Android clients |
Egress features |
User management, ACE based on user groups, and rate limiting for individual users Egress routing, ISP address library, Reverse Path Limited (RPL), domain name-based routing, and multi-link load balance (MLLB) DNS proxy, reverse DNS proxy, and DNS redirect Flow table-based attack prevention, single-user session limit, flow attack log, and flow table memory optimization Configuration backup and one-click recovery Flow log and URL log |
Security zone |
Security zone division based on the IP address Security zone division based on the logical interface Attack defense domain (global protection policies, protocol policies, and domain policies) Security audit (attack defense domain log audit, security zone log audit, and management log audit) |
URL filtering |
Self-defined URL and URL logs Automatic remote upgrade of URL library through HTTP Local storage of logs and storage on external log servers (including NAT logs, flow logs, and URL logs)
Attack prevention |
ARP attack prevention LAN attack prevention and WAN attack prevention Secure address binding Port scan attack prevention Segmentation packet attack prevention ICMP flood attack prevention Smurf attack prevention Teardrop attack prevention ICMP redirect attack prevention ICMP unreachable attack prevention |
Application Identification |
Self-developed application identification function that can identify various application types, customizable application identification protocol P2P applications Streaming media software Chat software Game software Internal enterprise applications |
Content audit |
Email content audit IM audit BBS forum content audit Search engine audit |
EMB module |
Device status query |
Query device details, CPU/memory usage, interface status, temperature, power supply, fan, traffic, and bandwidth utilization |
Network configuration |
VLAN management, trunk management, port setting, aggregate port, port mirroring, port rate limiting, static routing, DHCP, DHCP snooping, STP loop guard, RLDP, and remote power supply management |
Zero- configuration features |
CPE WAN Management Protocol (CWMP) |
Network management configurations |
Syslog, Telnet, and SNMP |
Diagnosis tools |
Network detection and one-click information collection |
Operations on devices |
Upgrade, restart, configuration management, system time, log server, DNS server, system character set, and web console |
Quick configuration |
Operation log |
Log query, log type, and log management |
Device upgrade |
Device upgrade |
Administrator account |
Web administrator configuration |
Data backup and recovery |
Data backup download, data import and recovery |
M7008L-RCM |
Quad-core processor |
BOOTROM |
16 MB, and dual boot for active and standby chips |
Flash Memory |
4GB |
SDRAM |
4GB |
External Port |
1 x console port |
Button |
1 x FUNC button |
Hot Swapping |
Supported |
EMC Standard |
GB/T 9254.1 |
Safety Standard |
GB 4943.1 |
Altitude |
● Maximum operating altitude: 5000 m (16404.20 ft.) ● Maximum storage altitude: 5000 m |
Operating Temperature |
0ºC to 45ºC (32ºF to 113ºF) (0 m to 1800 m) For the altitude in the range of 1800 m (5905.51 ft.) to 5000 m (16404.20 ft.), every time the altitude increases by 200 m (656.17 ft.), the operating temperature is decreased by 1°C (1.8ºF). |
Operating Humidity |
Storage Temperature |
–40ºC to +70ºC (–40ºF to +158ºF) |
Storage Humidity |
0.30 kg (0.66 lbs) |
Without captive screws: 86 mm x 208 mm x 38 mm (3.39 in. x 8.19 in. x 1.50 in.) With captive screws: 86 mm x 220 mm x 38 mm (3.39 in. x 8.66 in. x 1.50 in.) |
M7000L-6XS |
Port Type |
6 x SFP+ ports, supporting the 10G SFP+ module and 1G SFP module (there are slot limitations on the 1G SFP module) |
Optical Module |
SFP+ port SFP modules and SFP BIDI modules SFP+ modules, SFP+ cables, and SFP+ BIDI modules |
LED |
RDY, Link/ACT LED |
EMC Standard |
GB/T 9254.1 |
Hot Swapping |
Supported |
Altitude |
Storage Humidity |
Without captive screws: 86 mm x 209 mm x 38 mm (3.39 in. x 8.23 in. x 1.50 in.) With captive screws: 86 mm x 220 mm x 38 mm (3.39 in. x 8.66 in. x 1.50 in.) |
M7000-HDD-1T |
Hard Drive Type |
Hard Disk Drive (HDD) |
Capacity |
1 TB |
LED |
DISK status LED |
Hot Swapping |
Not Supported |
EMC Standard |
GB/T 9254.1 |
Safety Standard |
GB 4943.1 |
Altitude |
Storage Humidity |
159 mm x 100.2 mm x 20.5 mm (6.30 in. x 3.94 in. x 0.81 in.) |
M7000L-8GT |
Port |
8 x 10/100/1000BASE-T RJ45 ports |
Transmission Medium |
10/100/1000BASE-T Category 5 UTP |
LED |
RDY function module status LED or 10/100/1000Base-T Ethernet port LED |
Hot Swapping |
Supported |
EMC Standard |
GB/T 9254.1 |
Safety Standard |
GB 4943.1 |
Altitude |
Storage Humidity |
0.20 kg (0.44 lbs) |
Without captive screws: 198 mm x 86 mm x 38 mm (7.80 in. x 3.39 in. x 1.50 in.) With captive screws: 210 mm x 86 mm x 38 mm (8.27 in. x 3.39 in. x 1.50 in.) |
M7000L-8GT-HP |
Port |
All RJ45 ports support PoE+ and each port provides up to 30 W of power. The maximum power is subject to the configured power supply. Note The PoE+ port conforms to the PoE (IEEE802.3af) and PoE+ (IEEE802.3at) standards. The maximum number of PoE devices supported by the device is subject to the available PoE consumption of the device and the actual PoE consumption of each device. The PoE port is compliant with Alternative A. |
LED |
RDY function module status LED and 10/100/1000Base-T Ethernet port LED |
Hot Swapping |
Supported |
EMC Standard |
GB/T 9254.1 |
Safety Standard |
GB 4943.1 |
Altitude |
0ºC to 45ºC (32ºF to 113ºF) (0 m to 1800 m) For the altitude in the range of 1800 m (5905.51 ft. to 5000 m (16404.20 ft.), every time the altitude increases by 200 m (656.17 ft.), the operating temperature is decreased by 1°C (1.8ºF). |
Storage Humidity |
0.25 kg (0.55 lbs) |
M7000L-8SFP |
Port |
8 x SFP ports that support the 1G SFP module |
Optical Module |
SFP modules and SFP BIDI modules |
LED |
RDY function module status LED and SFP port LED |
Hot Swapping |
Supported |
EMC Standard |
GB/T 9254.1 |
Safety Standard |
GB 4943.1 |
Altitude |
Storage Humidity |
Without captive screws: 199 mm x 86 mm x 38 mm (7.83 in. x 3.39 in. x 1.50 in.) With captive screws: 210 mm 86 mm x 38 mm (8.27 in. x 3.39 in. x 1.50 in.) |
RG-PA180I-F |
Rated Voltage Range |
110 V/220 V AC, 50 Hz to 60 Hz |
Maximum Voltage Range |
90 V AC to 290 V AC, 45 Hz to 65 Hz |
Maximum Output Power |
180 W |
HVDC Parameters |
192 V DC to 290 V DC, 2A Max., 180 W |
0.45 kg (0.99 lbs) |
Power Cord |
10 A |
RG-PA650I-P-F |
650 W (12 V/10.83 A/130 W, 54.5 V/9.54 A/520 W) |
HVDC Parameters |
192 V DC to 290 V DC, 650 W (12 V/10.83 A/130 W, 54.5 V/9.54 A/520 W) |
0.85 kg (1.87 lbs) |
Power Cord |
10 A |
RG-SG7008L |
The RG-SG7008L chassis provides six interface card slots (slots 1–6), two multi-service card slots (slots 7–8), three built-in fixed fan modules, and two power module slots. Interface cards, multi-service cards, and power modules support hot swapping and need to be purchased separately. |
Multi-service Cards
M7008L-RCM |
High-performance first-generation routing card of the RG-SG7008L |
M7000L-6XS |
6 x 10GE optical interfaces (SFP+ and LC) |
Interface Cards
M7000L-8GT |
8 x GE electrical interfaces (RJ45) |
M7000L-8GT-HP |
8 x GE electrical interfaces (RJ45) that support PoE/PoE+ power supply |
M7000L-8SFP |
8 x GE optical interfaces (SFP+ and LC) |
RG-PA180I-F |
Power module (AC, 180 W, 10 A) |
RG-PA650I-P-F |
Power module (redundancy supported, AC, 650 W, 10 A) |
Contactați-ne
