RG-CS85-24GT8XS-D
RG-CS85-24SFP/8GT8XS-D
RG-CS85-48GT4XS-D
RG-CS85-48GT4XS-HPD
RG-CS85-48SFP4XS-D
Fan module
3 fixed fans
3 fixed fans
3 fixed fans
2 modular fans
3 modular fans
Expansion slot
One expansion slot
One expansion slot
One expansion slot
One expansion slot
One expansion slot
512 Mpps
512 Mpps
488 Mpps
488 Mpps
488 Mpps
688 Gbps
688 Gbps
656 Gbps
656 Gbps
656 Gbps
Ingress: 7,000
4.4 kg (9.70 lbs)
5.5 kg (12.12 lbs)
5.3 kg (11.68 lbs)
Dual-core CPU, 1.2 GHz
4 GB
4 GB
4 GB
4 GB
4 GB
<110 W (non-PoE)
<1,590 W (PoE full load)
<150 W
RG-PA150IB-F: 150 W
RG-PA150IB-F: 150 W
RG-PA150IB-F: 150 W
176 V AC to 290 V AC, 1000 W
AC: 100 V to 240 V
HVDC: 240 V
LVDC: 48 V to 60 V
AC:
200 V to 240 V
DC: -48 V to -60 V
AC: 100 V to 240 V
DC: -48 V to -60 V
AC: 90 V to 264 V
HVDC: 192 V to 288 V
LVDC: 36 V to 75 V
AC: 176 V to 264 V
DC: -38 V to -75 V
AC: 90 V to 264 V
DC: -36 V to -75 V
≥ 1,051,000 hours
≥ 823,000 hours
≥ 963,000 hours
≥ 832,000 hours
≥ 788,000 hours
45°C: 56.2 dB
45°C: 57.1 dB
45°C: 57.9 dB
27°C: 50 dB
45°C: 65 dB
27°C: 53 dB
45°C: 68 dB
Power port: 6 kV/6 kV
RG-CS85 Series
RG-CS85-24GT8XS-D
RG-CS85-48GT4XS-D
RG-CS85-48GT4XS-HPD
RG-CS85-48SFP4XS-D
CM85-4XS2CQ
150 W AC power supply module
Contactați-ne
Contactați-ne
Contactați-ne
Contactați-ne
