RG-S6910-3C |
Ports |
100GE/400GbE ports |
Slots |
4 |
Expansion Module Slots |
Three expansion slots, each slot supporting the line card with 32 x 100GbE ports or 8 x 400GbE ports |
Expansion module |
Four power module slots Six fan module slots |
Management Port |
One management port, one console port, and one USB port |
Switching Capacity |
19.2 Tbps |
Packet Forwarding Rate |
4000 Mpps |
802.1Q VLAN |
4094 |
RG-S6910-3C |
Dimensions (W × D × H) |
442 mm x 735 mm × 173.6 mm (17.40 in. x 28.94 in. x 6.83 in.,4 RU) |
About 42 kg (92.59 lbs., including four power modules, six fans, and three subcard modules) |
RG-S6910-3C |
AC |
● Rated voltage: 110 V AC/ 220 V AC ● Rated voltage range: 100 V AC to 240 V AC, 50 Hz to 60 Hz ● Max voltage range: 90 V AC to 264 V AC, 47 Hz to 63 Hz |
High-voltage DC |
Input voltage range: 180 V DC to 300 V DC |
Maximum Power Consumption |
● Max: 2046 W ● Typical: 1092 W ● Static: 760 W |
RG-S6910-3C |
Operating Temperature |
0ºC to 40ºC (32ºF to 104ºF) |
-40 °C to +70 °C (-40 °F to +158 °F) |
Operating Humidity |
10% RH to 90% RH (Non-condensing) |
Working altitude |
Software Specifications |
RG-S6910-3C |
Docker gRPC APIs in Docker |
L2 Protocols |
IEEE 802.3ae (10GBase), IEEE 802.3ak, IEEE 802.3an, IEEE 802.3x, IEEE 802.3ad (link aggregation), IEEE 802.1p, IEEE 802.1Q, IEEE 802.1D (STP), IEEE 802.1w (RSTP), IEEE 802.1s (MSTP), IGMP Snooping, Jumbo Frame (9 KB), IEEE 802.1ad (QinQ), GVRP |
L3 Protocols (IPv4) |
BGP4, OSPFv2, RIPv1, RIPv2, MBGP, LPM Routing, Policy-based Routing, Route-policy, ECMP, WCMP, VRRP, IGMP v1/v2/v3, PIM-SSM/SM/DM, MSDP, Any-RP |
IPv6 Basic Protocols |
IPv6 Features |
Static routing, ECMP, PBR, OSPFv3, RIPng, BGP4+, MLDv1/v2, PIM-SMv6, manual tunneling, IPv4 over IPv6 tunneling |
Visualization |
gRPC sFLOW and IPFIX |
IGMP Proxy、IGMP v1, v2, v3、IGMP Host Behavior、Querier Election、Member Query and Response、Static Multicast Route、IGMP Fast Leave、IGMP Filter、Layer-2 Multicast Forwarding Without Packet Loss、IGMPv1 and IGMPv2 Snooping、IVGL Mode、Querier、Source IP Address Check、Source Port Check、MLD Proxy、MLD v1 and v2、MLD Snooping、Coping with Traffic Burst Without Packet Loss、Layer-2 Multicast Forwarding Without Packet Loss、Source Port Check、MSDP、PIM-DM、PIM-SMv6、PIM-SSMv6、PIM-SM、PIM-SSM |
ACL |
ACL 80、Dual-stack Networking、ACL-based Redirection、IPv6 ACL、Standard IP-based ACL、Extended IP-based ACL、Extended MAC-based ACL、Ingress/Egress ACLs、Time-based ACL、Global ACL、ACL Counter、ACL Logging、ACL Re-marking、Displaying ACL Resource Usage、Expert-level ACL |
QoS |
Mapping of 802.1p, DSCP, and ToS priorities, ACL-based traffic classification, priority marking/remarking, multiple queue scheduling mechanisms available including SP, WFQ, and SP+WRR |
Data center features |
The MMU queue ID ranges from 0 to 7. Buffer Occupation/Queue Traffic Statistics/Packet Loss Report Through gRPC Flow Suspension Prevention MMU Displaying Lost Packets and Alarms Due to Buffer Congestion on an Interface Real-Time Buffer Monitoring Reading Statistics of Unicast Packet Loss Due to Buffer Congestion Through MIB |
HA Design |
GR for RIP/OSPF/BGP, BFD, REUP dual-link fast switching and RLDP unidirectional link detection, 1+1 power redundancy and fan redundancy, and hot swap for all cards and power modules |
Security Features |
Network foundation protection policy, CPP, DDoS attack defense, illegitimate packet detection, data encryption, source IP spoofing prevention, IP scanning prevention, RADIUS/TACACS, IPv4/v6 packet filtering by basic ACL, extended ACL or VLAN-based ACL, plaintext-based and MD5 ciphertext-based authentication for OSPF, RIPv2, and BGPv4 packets, telnet login and password mechanisms for restricted IP addresses, uRPF, broadcast packet suppression |
Management Mode |
SNMP v1/v2c/v3, telnet, console, MGMT, RMON, SSHv1/v2, FTP/TFTP, NTP, syslog, and SPAN/RSPAN/ERSPAN |
Other Protocols |
Specification |
RG-S6910-3C |
Safety |
● UL 62368-1 ● CSA C22.2 No. 62368-1 ● IEC 62368-1 ● EN 62368-1 ● BS EN 62368-1 ● GB 4943.1 |
● EN 55032 ● EN 55035 ● EN 61000-3-2 ● EN 61000-3-3 ● BS EN55032 ● BS EN 55035 ● BS EN 61000-3-2 ● BS EN61000-3-3 ● EN 300 386 ● ANSI C63.4 ● 47 CFR FCC Part 15 Subpart B ● ICES-003 Issue 7 ● GB/T 9254.1 |
Environment |
RG-S6910-3C |
Three expansion slot, four power module slots, and six fan module slots The power module model is RG-PA1200I-F and the fan model is M2EFAN I-F. |
M6900-32CQ |
32-port 100GbE card |
RG-PA1200I-F |
RG-S6910-3C power module, supporting 2+2 redundancy, hot swapping, and front-to-rear ventilation design |
M2EFAN I-F |
RG-S6910-3C fan module, supporting 5+1 redundancy, hot swapping, and front-to-rear ventilation design |
Product Model |
100G-QSFP-SR-MM850 |
100G-QSFP-iLR4-SM1310 |
100G-QSFP-LR4-SM1310 |
100G-QSFP-ER4-SM1310 |
100G-AOC-5M |
100G-AOC-10M |
Product Model |
40G-QSFP-iLR4-SM1310 |
40G-QSFP-LR4-SM1310 |
40G-QSFP-LSR-MM850 |
40G-QSFP-SR-MM850 |
40G-QSFP-LX4-SM1310 |
40G-AOC-30M |
40G-AOC-5M |
Contactați-ne
