RG-S6980-64QC |
Ports |
Fixed 64 × 400GE ports (QSFP-DD) |
Expansion Module Slots |
Not supported |
Expansion Modules |
Four power supply module slots Eight fan module slots |
Management Port |
Switching Capacity |
51.2 Tbps |
Packet Forwarding Rate |
10300 Mpps |
802.1Q VLAN |
4094 |
RG-S6980-64QC |
Dimensions (W × D × H) |
442 mm x 760 mm x 175 mm (17.40 in. x 29.92 in. x 6.89 in., 4 RU) |
About 38 kg (83.78 lbs., including eight fan modules and four power supply modules) |
RG-S6980-64QC |
Maximum Power Consumption |
● Max: 2400 W ● Typical: 1760 W ● Static: 500 W |
AC |
AC input: Rated voltage range: 100 V AC to 127 V AC Frequency: 50 Hz to 60 Hz Rated input current: 13.8 A (max) Rated voltage range: 200 VAC to 240 VAC Frequency: 50 Hz to 60 Hz Rated input current: 8.5 A (max) |
High-voltage DC |
HVDC input: 180 V DC to 300 V DC Rated voltage: 240 V DC Rated input current: 6.5 A |
RG-S6980-64QC |
Operating Temperature |
0ºC to 40ºC (32ºF to 104ºF) |
-40 °C to +70 °C (-40 °F to +158 °F) |
Operating Humidity |
10% RH to 90% RH (Non-condensing) |
Working altitude |
Software Specifications |
RG-S6980-64QC |
L2 Protocols |
IEEE 802.3ae (10GBase), IEEE 802.3ak, IEEE 802.3an, IEEE 802.3x, IEEE 802.3ad (Link Aggregation Control Protocol)), IEEE 802.1p, IEEE 802.1Q, IEEE 802.1D (STP), IEEE 802.1w (RSTP), IEEE 802.1s (MSTP), Jumbo Frame (9 KB) |
L3 Protocols (IPv4) |
IPv6 Basic Protocols |
IPv6 Features |
Data Center Features |
Visualization |
gRPC sFLOW sampling |
QoS |
ACL |
ACL 80、ACL-based Redirection、IPv6 ACL、Standard/Extended IP/MAC-based ACL、Time-based ACL、Global ACL、ACL Counter、ACL Counter Only、ACL Logging、ACL Re-marking、Displaying ACL Resource Usage、Expert-level ACL、IPv4 UDF ACL、Global ACL Counter Only、Matching Against the Inner 5-Tuple of the VXLAN、IPv6 UDF ACL、Matching Against the Inner 5-Tuple of the Passing VXLAN、Ingress/Egress ACLs |
HA Design |
Security Features |
Network foundation protection policy (NFPP), CPP, RADIUS/TACACS, IPv4/v6 packet filtering by basic ACL, extended ACL or VLAN-based ACL, plaintext-based and MD5 ciphertext-based authentication for OSPF, RIPv2, and BGPv4 packets, telnet login and password mechanisms for restricted IP addresses, broadcast packet suppression, hierarchical user management |
Management Mode |
SNMP v1/v2c/v3, telnet, console, MGMT, RMON, SSHv1/v2, FTP/TFTP, NTP, Syslog, SPAN/RSPAN/ERSPAN, ZTP, NETCONF, Python, fan and power alarm, and temperature alarm |
Other Protocols |
Specification |
RG-S6980-64QC |
Safety |
● EN 55032 ● EN 55035 ● EN 61000-3-2 ● EN 61000-3-3 ● BS EN55032 ● BS EN 55035 ● BS EN 61000-3-2 ● BS EN 61000-3-3 ● EN 300 386 ● GB/T 9254.1 |
Environment |
The configuration procedure for the RG-S6980-64QC switch is as follows:
Product Model |
RG-S6980-64QC |
Fixed 64 × 400GE ports, four power supply module slots, and eight fan slots |
RG-PA1200I-F |
M2EFAN II-F |
Fan module, supporting 7+1 redundancy, hot swapping, and front-to-rear ventilation design |
Product Model |
400G-QDD-SR8-MM850 |
400G-QDD-FR4-SM1310 |
400G-QDD-DR4-SM1310 |
Product Model |
100G-QSFP-iLR4-SM1310 |
100G-QSFP-LR4-SM1310 |
100G-QSFP-SR-MM850 |
100G-QSFP-ER4-SM1310 |
100G-AOC-5M |
100G-AOC-10M |
Contactați-ne
